NI TestStand
Getting duplicate file when building deployment
I just upgraded from Dev Suite 2009 to 2010. I am using the same .tsd file to build a deployment. However I am now getting the following error when the build starts:
Error: The following VIs or Project Libraries have duplicate names
You must change the names or add them to project libraries:
C:\Program Files\National Instruments\LabVIEW 2010\vi.lib\picture\png.llb\Write PNG File.vi while Processing VIs...
C:\__views\calTest_jhite\mastrv\Deployments\MASTRV-CalAndTest\target\SupportVIs\Write PNG File.vi while Processing VIs...
C:\Program Files\National Instruments\LabVIEW 2010\vi.lib\picture\jpeg.llb\Write JPEG File.vi while Processing VIs...
C:\__views\calTest_jhite\mastrv\Deployments\MASTRV-CalAndTest\target\SupportVIs\Write JPEG File.vi while Processing VIs...
***************************************Error: The following VIs or Project Libraries have duplicate namesYou must change the names or add them to project libraries:C:\Program Files\National Instruments\LabVIEW 2010\vi.lib\picture\png.llb\Write PNG File.vi while Processing VIs...C:\__views\calTest_jvh\mastrv\Deployments\MASTRV-CalAndTest\target\SupportVIs\Write PNG File.vi while Processing VIs...C:\Program Files\National Instruments\LabVIEW 2010\vi.lib\picture\jpeg.llb\Write JPEG File.vi while Processing VIs...C:\__views\calTest_jvh\mastrv\Deployments\MASTRV-CalAndTest\target\SupportVIs\Write JPEG File.vi while Processing VIs...
and several hundred more like this. I clear out the deployment directory but still get this error. What's going on here?
thanks,
jvh
(3,291 Views)
Accepted by topic author jvh75021
Turns out my dependency paths got hosed by the update.
(3,281 Views)
