NI TestStand
Getting output parameters from stored procedures
I am calling a stored procedure in TestStand 4 however when I try to retrieve an output parameter using Get, an error of "The column '@X' was not returned from the SQL statement.".  I have setup the parameters including '@X' using Execute in the previous step.  I would appreciate it if someone could take a quick look to see if there is a small error being made.
(3,299 Views)
Try changing your operation from a Get to a Close ("Close - Close and Get output parameters").  The Get returns a record, while the Close should get the output value you want.
Mark E.
(3,248 Views)
