NI TestStand
Getting the value from a StationGlobal reference variable in TestExec User Interface Editor Mode.
I am using the TestExec User Interface editor mode, in the SequenceFileLoad callback from my sequence an instance is made from a C# code module
(the code module is located in another dll) , this reference is stored into a station global variable.
Now I want to retrieve the reference from the station global variable in my TestExec User Interface code.
So, is it possible to get this reference back from the station global variable?
Best regards
(3,296 Views)
ccds,
It sounds like your UI is written in .NET and you want to use an object created in your sequence in your UI.  This is generally a difficult thing to do because of .NET AppDomain issues.  Could you describe what you are trying to accomplish?  Because there's probably another (easier) way to implement it.
Josh W.
Certified TestStand Architect
Formerly blue
(3,199 Views)
Reading the StationGlobal is not a problem. But the problem maybe that your reference contained in your StationGlobal is probably not valid once the SequenceFileLoad has completed its execution which it will have done once the SequenceFile has loaded.
Any references you wish to pickup are best down via one of the ProcessModel callbacks such as ProcessSetup.
Regards
Ray Farmer
Regards
Ray Farmer
(3,195 Views)
