NI TestStand
Going back to TestStand 3.1
I have a sequence file that I developed in TestStand 3.5
What do I have to do to make it run under TestStand 3.1?
Is this possible without re-entering all of the individual statements?
(2,896 Views)
You can 'Save As' to TestStand 3.1 sequnece file. With Save  As Dialog open,  just select the File Type drop down control and select TestStand 3.1 *seq.
Assuming you are running it on the same PC, you would then have to close TestStand 3.5. Select the TestStand Version Selection Tool from the National Instruments menu items on your Start | All Programs button. Select TestStand 3.1 and make Active. Wait for the dialog to retuned completed. Press OK and close the TestStand Version Selection Tool.
You can now launch TestStand 31 and run your sequence file.
Regards
Ray Farmer
Regards
Ray Farmer
(2,892 Views)
