NI TestStand
Graph function problem in DLL when called from TestStand. OK when called from CVI.
I'm cross posting this from the CVI forum where it hasn't yet had a responce. It maybe more of a TestStand issue than CVI.
I have a DLL which I wrote using CVI.
There isn't a UIR file.
When the process attaches, I call a function which;
  • Creates a panel with NewPanel().
  • Creates a number of controls including a graph with NewCtrl().
  • Traps new panel and new control errors.
  • Sets various panel and control attributes.
  • It does not display the panel.
The DLL has two functions to use the panel and it's controls.
  • A function to add plots to the graph.
  • A function that displays the panel and waits for the user to close it.
If I call these function from a CVI test application they work as intended.
If I call the functions from TestStand with the CVI debugger attached they work as expected.
If I call the functions from TestStand without CVI debugging then about 95% of the time the functions fail.
Failure is always at the following functions;
  • DeleteGraphPlot()
  • PlotWaveform()
The error returned by the functions is -4 which is the error code for an invalid handle.
To try and debug this I have written the handles to a file as part of the error trap and compared them to the handles written to another file when the panel and controls are created. They are the same and therefore should be vaild.
There are several other functions in the DLL which work correctly with TestStand although none of them use a panel or controls.
I'd be grateful for any insights.
John.
John C
(5,286 Views)
Hi John,
To further allow me to understand the problem that you are having, could you please provide me with the versions of  software that you are using? (i.e. CVI, TestStand...)
(5,259 Views)
Development PC
Win 7 Home  64-bit Completely up to date.
CVI 2103 13.0.2 (278)
TestStand 2010
Deployment PC
Win XP Prof 32-bit. Completely up to date.
Does not have CVI development system installed.
TestStand 2014
I'm also happy to post the DLL project and a simple sequence file.
Cheers,
John
John C
(5,257 Views)
Hi John,
Yes posting those would be fantastic.
(5,253 Views)
CVI project, DLL and a simple sequence attached.
John C
(5,240 Views)
(5,233 Views)
