NI TestStand
[HELP] Global Force All Tests to Fail...
I have a project with 300 odd Sequence files.  When a test case in one of these sequences fails a sequence is called to suggest “fixes” for the failure in the report file.  For example a DC PSU test might suggest replacing the DC PSU.
I need a quick way of forcing all the Pass/Fail Test cases to fail on mass, so we can check that the report is updating correctly.  So the test may initially pass, but I want fail to be reported.  Is this possible?
We are using TestStand 3.5.
Christopher Povey
Principle Test Systems Engineer for BAE Systems.
(2,980 Views)
Hey Christopher,
You can force a step to fail by right clicking it and selecting Run Mode > Force Fail.  You can Ctrl+click multiple steps and this will still work, or use CTRL+A.
Does this help?
Kind Regards,
Dominic Walker
Cardiff University
Electrical and Electronic Engineering Student
(2,953 Views)
