NI TestStand
[HELP] Teststand error when using labView runtime engine...
I have an extensive TestStand 3.5 project which I am working on.  This project uses a large number of LabVIEW 2012 VI’s.  (Note: The version of TestStand cannot be changed).  When TestStand 3.5 LabVIEW Adaptor is configured to “Development System (Active Version: 12.0)” all the sequence run and perform as expected.
When I change the TestStand 3.5 LabVIEW Adaptor is configured to “LabVIEW Run-Time Engine 12.0” then I get an -18002 error in the first VI called by the sequence and nothing runs.  Now this sequence contains a standard library VI in it “Check if File or Folder Exists.vi”.
From research I realised that I needed to deploy the software properly.  So created a LabVIEW project with all the sequences and VI’s in it and a “Source Distribution”.  I also unchecked “Exclude files from vi.lib”, “Exclude files from instr.lib”, and, “Exclude files from user.lib”.  After building the project I get a “data” folder full of VI’s and control files (273 of them).
Next I created an “Installer” and added build to the correct place.  I can see the “data” folder in the source files section.
When I install this distribution kit on a PC, which happens to have full LabVIEW 2012 development on it, all the files install but the “data” folder is missed out!!!
If I then attempt to run the installed top level sequence I get the same -18002 broken VI error as before.  If I manually copy the “data” folder into the same place as it was built it makes no difference.
Anyone got any suggestions?
Christopher Povey
Principle Test Systems Engineer for BAE Systems.
(4,632 Views)
Bit of additional information:
I created a blank LabVIEW 2012 project. To this I added one VI which included a call to "Check if File or Folder Exists.vi". Then added one TestStand 3.5 Sequence which contained a call to the VI above.
I then added a build to the project and built the project. This resulted in a folder with the sequence file, my VI and a Data folder containing the "Check if File or Folder Exists.vi". When I tried to run the TestStand sequence with LabVIEW Run-Time Engine selected it failed as before.
Next I added another LabVIEW step to my sequence calling "Check if File or Folder Exists.vi" from the "Data" folder. It then worked!
I then modified my VI and added the MD5 checker VI (forget the exact name). It added some files to the dependences in the LabVIEW project. I rebuilt it and ran it again and again it worked. I did not need to add the additional VI's in the "Data" folder to the sequence file.
If I remove the LabVIEW step to my sequence calling "Check if File or Folder Exists.vi" though it breaks again.
This is not ideal though as it is a bit chicken and egg. In order for the project to work I need to add one of the VI's from the generated "Data" folder into a sequence in the project, but I can't do that until I build the project to create the "Data" folder!
Christopher Povey
(4,619 Views)
