NI TestStand
HP Quality Center - Risk Based Analysis
Hi All,
Can anyone assist me on the below queries,
I am able to perform Risk Based Quality Management on Requirements , Is there any features to perform RBQM on Test Case level?
While performing RBQM on requirements it gives me requirements based on total testing time. Is there a feature where it automatically maps the resources for the fetched requriements.
Thanks in Advance
Monisha
(5,031 Views)
I guess I'm not quite sure what you are asking as I've never dealt with RBQM.
However, TestStand integrates into DOORS and Requirements Gateway quite nicely.  Here is a whitepaper on it:
http://www.ni.com/white-paper/8422/en/
Basically in TestStand you can assign requirements to steps and then use a tool (Requirements Gateway or other tool) to analyze the file to see if all requirements are being met.
Hopefully this is somewhat helpful.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,957 Views)
Hi. I have the exact same question as you.  Were you ever able to resolve?
(3,715 Views)
