NI TestStand
HPVEE,.NET
Hi, I am trying to run a HPVEE function inside TestStand using activeX server as in the example. It gives me an error  ".NET cannot create an instance" because I am using .NET inside HPVEE function. Please advise. Does TestStand 3.0 support this?
(4,048 Views)
If you have created your HPVEE program into an assembly you should be able to use the .NET adapter in TestStand to call into the assembly.  If you are calling straight into HPVEE then you should take a look at the example program that ships with TestStand:
C:\Program Files\National Instruments\TestStand 3.0\Examples\VEE
Use this as a basis for using TestStand with HPVEE.
Also, the error you reported seems to me that it may not be a TestStand error but an error with your communication between VEE and .NET.  Can you try taking TestStand out of the equation and testing your HPVEE program by itself so that we can try and isolate the issue.
Caroline
Caroline Tipton
Data Management Product Manager
(4,026 Views)
Thanks for your reply.
When I run HPVEE, it works fine.
I do use the example provided by NI and copied the VEE step types into my test sequences.
I am able to step through the VEE function when I put the debug mode when I specify the module in the testStand. It complains it can not create .NET object even though it runs perfectly fine in VEE itself.
I appreciate it any feedback.
(4,021 Views)
Just a wild guess, but something to try would be to move your steps into a subsequence and in the call to the subsequence, specify to Run Sequence in a New Thread.
On the Settings... dialog, check the Use Single-Threaded Apartment option.
(4,002 Views)
Have you figured this problem out yet? Have you tried installing the HP Vee run-time engine?
(3,934 Views)
