NI TestStand
HTLM not interpreted in report window 3.1 from 2.0
We have a TestStand 2.0 based sequence.  When it is finished it produces a formatted report.  When I converted it to a 3.1 sequence the report looks like the source display of the page not the formatted output. Any clues?
thanks,
sahc
(6,694 Views)
XML isn't HTMLSmiley Surprised Your browser needs to know where the xsl file is. You need a line like this:
<?xml-stylesheet type="text/xsl" href="simple.xsl"?>
If you don't want the report to be in xml you need to change the reporting option to html from the TestStand editor.
Hope this helps.
kph
(6,685 Views)
That was it.
(6,670 Views)
