NI TestStand
Handle complicated and mass output
I have a Labview VI that has a very comlicated output(array of container of array...).I don't want to create a variable in TestStand ,is there a way that use a reference or variant ... to receive that output?
(3,693 Views)
You are aware that the LV adapter provides a tool called "Create/Update Custom Data Type". There is a "type" button in the parameter list of the VI in the Type column. The symbol of the button looks identical to the symbol shown on the Type Palette button in the tool bar.
Norbert
Norbert
Expert: Geometry
(3,642 Views)
