Hi Sunny,
Currently, you cannot call ActiveX controls using the ActiveX Automation Adapter in TestStand. To do this, you would need to call a code module that was set to display/utilize the control, and retrieve all of the events generated by the control. TestStand can only currently call ActiveX servers (either DLL or EXE) that support the IDispatch interface. Hope this answers your question.
Bob
