NI TestStand
Have I hosed TestStand???
Hello  Everyone,
I started working with test stabd for the last few days.   As I was working with examples on NI site,  I all suddenly ran into this error Message:
Parameter 'Return Value': Unknown variable or property name 'Parameters.ReportOptions.UseLocalizedDecimalPoint'.
-17306; Unknown variable or property name.
Step 'GetLocalizedDecimalPointOptionValue' of sequence 'Get Report Options' in 'SequentialModel.Seq'
Happens now with any Seq I open up.
When I choose to ignore this, problem, other Errors occur  such as
-17329; Invalid type - conflicts with an existing type.
How it can't do clean up, nor produce xml file
Is there a fix for this....other then unistalling/reinstalling TestStand?
(3,085 Views)
Hi Tony:
When you go to Configure>>Report Options, a dialog box will show up. I suspect a setting there might have changed. Could you take a screenshot of the dialog box?
Thank you
Nandini
NI
(3,068 Views)
Hi Tony,
What example was you working on, it might pin point your problem.
Regards
Ray Farmer
Regards
Ray Farmer
(3,065 Views)
