NI TestStand
Help me so I don't need to install TS2014 64bit
I have been caught up in CAR 597768
Source files for some process model components cannot be opened.
Opening any of the following projects results in an error about missing NI_Common.props:
OfflineResultsProcessingUtility.csproj
OfflineResultsProcessingUtilityData.csproj
OfflineResultsProcessingUtilityUAC.csproj
ManagedModelSupport.csproj
TSOTFRG.vcxproj
DBLog.vcxproj
Workaround: Use project files from TestStand 2014.
I am very interested in specifically DBLog.vcxproj for TS 64bit.  Can someone post that file (should be in c:\program files\national instruments\teststand 2014\components\models\teststandmodels\database\dblog\) for TS 2014 64bit. (so I don't need to dig up and install TS2014 on my system....)
(2,828 Views)
Attached you will find the TestStand 2014 SP1 (64-bit) version of the project file.
Scott Richardson
https://testeract.com
(2,781 Views)
