Hi RJM,
The easies way is to select your step. Right mouse click and select 'Properties...'.
A Properties Dialogbox will appear. Select the 'Expressions' Tab.
Enter your expression in the Pre or Post Expression edit box.
You can use the Browse button to help you build up your expression from Variables and functions and check the syntax.
Hope this helps
Ray Farmer
Regards
Ray Farmer
