NI TestStand
Help out a Newbie - TestStand reporting
Hello folks
I am totally new at TestStand at currently struggle with the configuration of a sequence
I would like to develop a sequence, from which, my device (UUT) connected to the pc with USB, would return a report to me containing, i.e. the Serial Number.
I am quite lost, and seek guidance in how to do so.
Thanks in advance! Best regards, Andedam
(1,286 Views)
You should check out the Overriding PreUUT Model Callback example - it shows one way to accomplish this. Any of the default reports (Configure » Report Options) should include the serial number in the header.
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(1,236 Views)
