NI TestStand
Hidden "Serial Number" field from TestStand report header
Hi!
Is it possible to hide the "Serial Number" filed from the default TestStand report header? If yes, how?
Thanks.
(1,691 Views)
Do you mean to say you dont want the serial number to appear in the html report?
Ravi
(1,647 Views)
Hi Ravi,
yes exactly. I have the report in html format and I want the field "Serial number" of the header not appear in the report. Is there any way to achieve this?
Thanks.
(1,640 Views)
Please try the following :
1) Add a Modify report header callback to your sequence ( Go to edit-->Sequence file callback--> Add Modify report header)
2( Go to Mpdify report header sequence and add a local variable locals.TestReplace :
Copy the following content to it :
Parameters.ReportHeader =  <a name="-1-2022-3-9-13-14-4-700"></a><h3>UUT Report</h3>
<table class='hdr'><tbody>
<tr><td class='hdr_name'><b>Station ID: </b></td><td class='hdr_value'><b>INSL-RSHRIGIR</b></td></tr>
<tr><td class='hdr_name'><b>Date: </b></td><td class='hdr_value'><b>09 March 2022</b></td></tr>
<tr><td class='hdr_name'><b>Time: </b></td><td class='hdr_value'><b>13:14:04</b></td></tr>
<tr><td class='hdr_name'><b>Operator: </b></td><td class='hdr_value'><b>administrator</b></td></tr>
<tr><td class='hdr_name'><b>Execution Time: </b></td><td class='hdr_value'><b>1.4906695 seconds</b></td></tr>
<tr><td class='hdr_name'><b>Number of Results: </b></td><td class='hdr_value'><b>1</b></td></tr>
<tr><td class='hdr_name'><b>UUT Result: </b></td><td class='hdr_value'><b><span style="color:#FF0000;">Failed</span></b></td></tr>
<tr><td class='hdr_name'><b>Failure Chain:</b></td></tr>
</tbody></table><br><table style="border-color:#000000;"><tbody>
<tr><td style="border-color:#000000;background-color:#FF2020;"><b>Step</b></td><td style="border-color:#000000;background-color:#FF2020;"><b>Sequence</b></td><td style="border-color:#000000;background-color:#FF2020;"><b>Sequence File</b></td></tr>
<tr><td style="border-color:#000000;background-color:#D0D0D0;"><a href="#ResultID5">Numeric Limit Test</a></td><td style="border-color:#000000;background-color:#D0D0D0;">MainSequence</td><td style="border-color:#000000;background-color:#D0D0D0;">Unsaved Sequence File</td></tr>
<hr style="color:#8000CC;background-color:#8000CC;border-width:0;width:50%;height:3px;text-align:left;margin-left:0;">
3) Add a statement  with the following :
Parameters.ReportHeader=Locals.TextReplace
This should resolve your issue.
Ravi
(1,637 Views)
Thank you. And for reports in XML format (ATML 5.00)?
(1,629 Views)
Refer to my previous reply.For XML report Change this :
locals.TextReplace = <Report Type='UUT' Title='UUT Report' Link='-1-2022-3-10-23-24-17-19' UUTResult='Failed' StepCount='1'>
<Prop Name='UUT' Type='Obj' TypeName='UUT' Flags='0x0'>
<Prop Name='Serial' Type='String' Flags='0x0'>
<Value></Value>
</Prop>
<Prop Name='UUTLoopIndex' Type='Number' Flags='0x0'>
<Value>0</Value>
</Prop>
<Prop Name='CriticalFailureStack' Type='Array' LBound='[0]' HBound='[0]' ElementType='Obj' Flags='0x0'>
<ArrayElementPrototype Type='Obj' TypeName='NI_CriticalFailureStackEntry' Flags='0x0'>
<Prop Name='StepName' Type='String' Flags='0x0'>
<Value></Value>
</Prop>
<Prop Name='SequenceName' Type='String' Flags='0x0'>
<Value></Value>
</Prop>
<Prop Name='SequenceFileName' Type='String' Flags='0x0'>
<Value></Value>
</Prop>
<Prop Name='ResultId' Type='Number' Flags='0x0'>
<Value>0</Value>
</Prop>
</ArrayElementPrototype>
<Value ID='[0]'>
<Prop Type='Obj' TypeName='NI_CriticalFailureStackEntry' Flags='0x0'>
<Value>Numeric Limit Test</Value>
</Prop>
<Value>MainSequence</Value>
</Prop>
<Value>Sequence File 1.seq</Value>
</Prop>
<Value>5</Value>
</Prop>
</Prop>
</Value>
</Prop>
<Prop Name='BatchSerialNumber' Type='String' Flags='0x0'>
<Value></Value>
</Prop>
<Prop Name='TestSocketIndex' Type='Number' Flags='0x0'>
<Value>-1</Value>
</Prop>
<Prop Name='PartNumber' Type='String' Flags='0x0'>
<Value></Value>
</Prop>
<Prop Name='AdditionalData' Type='Obj' Flags='0x200000'>
</Prop>
</Prop>
<Prop Name='ReportOptions' Type='Obj' TypeName='ReportOptions' Flags='0x0'>
<Attributes>
<Prop Name='NI' Type='Obj' Flags='0x0'>
<Prop Name='EnabledExpression' Type='String' TypeName='Expression' Class='ExprValue' Flags='0x0'>
<Value>Runstate.Engine.CurrentUserHasPrivilege("Configure.ConfigReport")</Value>
</Prop>
<Prop Name='Implemented' Type='Boolean' Flags='0x0'>
<Value>True</Value>
</Prop>
</Prop>
</Attributes>
<Prop Name='IncludeTSExtensionElements' Type='Boolean' Flags='0x0'>
<Value>True</Value>
</Prop>
<Prop Name='IncludeAttributes' Type='Boolean' Flags='0x0'>
<Value>False</Value>
</Prop>
<Prop Name='IncludeLimits' Type='Boolean' Flags='0x0'>
<Value>True</Value>
</Prop>
<Prop Name='IncludeMeasurements' Type='Boolean' Flags='0x0'>
<Value>True</Value>
</Prop>
<Prop Name='IncludeArrayMeasurement' Type='Number' Flags='0x0'>
<Value>2</Value>
</Prop>
<Prop Name='ArrayMeasurementFilter' Type='Number' Flags='0x0'>
<Value>3</Value>
</Prop>
<Prop Name='ArrayMeasurementMax' Type='Number' Flags='0x0'>
<Value>10000</Value>
</Prop>
<Prop Name='IncludeTimes' Type='Boolean' Flags='0x0'>
<Value>True</Value>
</Prop>
<Prop Name='Format' Type='String' Flags='0x0'>
<Value>xml</Value>
</Prop>
<Prop Name='NumericFormat' Type='String' Flags='0x0'>
<Value>%$.13g</Value>
</Prop>
<Prop Name='ResultFilterExpression' Type='String' TypeName='Expression' Class='ExprValue' Flags='0x0'>
<Value>Left(Result.TS.StepType, 7) != "NI_Flow"</Value>
</Prop>
<Prop Name='GeneratePath' Type='Boolean' Flags='0x0'>
<Value>True</Value>
</Prop>
<Prop Name='UseTemporaryFile' Type='Boolean' Flags='0x0'>
</Prop>
<Prop Name='UseSequenceFileNameAsPrefix' Type='Boolean' Flags='0x0'>
<Value>True</Value>
</Prop>
<Prop Name='AddTimeAndDateToFileName' Type='Boolean' Flags='0x0'>
<Value>True</Value>
</Prop>
<Prop Name='NewFileNameForEachUUT' Type='Boolean' Flags='0x0'>
<Value>True</Value>
</Prop>
<Prop Name='ForceFileNameToBeUnique' Type='Boolean' Flags='0x0'>
<Value>True</Value>
</Prop>
<Prop Name='AppendToFileIfItExists' Type='Boolean' Flags='0x0'>
</Prop>
<Prop Name='DirectoryType' Type='String' Flags='0x0'>
<Value>SpecifyByExpression</Value>
</Prop>
<Prop Name='Directory' Type='String' Flags='0x0'>
<Value></Value>
</Prop>
<Prop Name='BaseName' Type='String' Flags='0x0'>
<Value>Report</Value>
</Prop>
<Prop Name='UseFormatForExtension' Type='Boolean' Flags='0x0'>
<Value>True</Value>
</Prop>
<Prop Name='Extension' Type='String' Flags='0x0'>
<Value></Value>
</Prop>
<Prop Name='ReportFilePath' Type='String' Flags='0x0'>
<Value></Value>
</Prop>
<Prop Name='DisableReportGeneration' Type='Boolean' Flags='0x0'>
</Prop>
<Prop Name='IncludeStepResults' Type='Boolean' Flags='0x0'>
<Value>True</Value>
</Prop>
<Prop Name='BodyGenerator' Type='String' Flags='0x0'>
<Value>Sequence</Value>
</Prop>
<Prop Name='Colors' Type='Obj' Flags='0x0'>
<Prop Name='LabelBg' Type='String' Flags='0x0'>
<Value>#FFFFFF</Value>
</Prop>
<Prop Name='ValueBg' Type='String' Flags='0x0'>
<Value>#32FFFF</Value>
</Prop>
<Prop Name='UUTSeparator' Type='String' Flags='0x0'>
<Value>#0000E0</Value>
</Prop>
<Prop Name='HeaderSeparator' Type='String' Flags='0x0'>
<Value>#8000CC</Value>
</Prop>
<Prop Name='TableBorder' Type='String' Flags='0x0'>
<Value>#000000</Value>
</Prop>
<Prop Name='MainBg' Type='String' Flags='0x0'>
<Value>#00C4C4</Value>
</Prop>
<Prop Name='SetupBg' Type='String' Flags='0x0'>
<Value>#FF8000</Value>
</Prop>
<Prop Name='CleanupBg' Type='String' Flags='0x0'>
<Value>#ADD8E6</Value>
</Prop>
<Prop Name='ReportTextBg' Type='String' Flags='0x0'>
<Value>#FF32CC</Value>
</Prop>
<Prop Name='Terminated' Type='String' Flags='0x0'>
<Value>#000080</Value>
</Prop>
<Prop Name='Failed' Type='String' Flags='0x0'>
<Value>#FF0000</Value>
</Prop>
<Prop Name='Error' Type='String' Flags='0x0'>
</Prop>
<Prop Name='Passed' Type='String' Flags='0x0'>
<Value>#008000</Value>
</Prop>
<Prop Name='Skipped' Type='String' Flags='0x0'>
<Value>#B98028</Value>
</Prop>
<Prop Name='Done' Type='String' Flags='0x0'>
</Prop>
<Prop Name='Running' Type='String' Flags='0x0'>
<Value>#FFCC33</Value>
</Prop>
<Prop Name='TerminatedBg' Type='String' Flags='0x0'>
<Value>#0000FF</Value>
</Prop>
<Prop Name='FailedBg' Type='String' Flags='0x0'>
</Prop>
<Prop Name='ErrorBg' Type='String' Flags='0x0'>
</Prop>
<Prop Name='PassedBg' Type='String' Flags='0x0'>
<Value>#00FF00</Value>
</Prop>
<Prop Name='SkippedBg' Type='String' Flags='0x0'>
<Value>#FFFF00</Value>
</Prop>
<Prop Name='DoneBg' Type='String' Flags='0x0'>
<Value>#00FFCC</Value>
</Prop>
<Prop Name='RunningBg' Type='String' Flags='0x0'>
</Prop>
<Prop Name='FailureStackLabelBg' Type='String' Flags='0x0'>
<Value>#FF2020</Value>
</Prop>
<Prop Name='FailureStackValueBg' Type='String' Flags='0x0'>
<Value>#D0D0D0</Value>
</Prop>
<Prop Name='BatchHeadingBg' Type='String' Flags='0x0'>
</Prop>
</Prop>
<Prop Name='DateAndTimeFormat' Type='String' Flags='0x0'>
<Value>TimeFirst</Value>
</Prop>
<Prop Name='NewFileNameForEachBatch' Type='Boolean' Flags='0x0'>
</Prop>
<Prop Name='NewBatchFileNameForEachBatch' Type='Boolean' Flags='0x0'>
</Prop>
<Prop Name='NewFileNameForEachTestSocket' Type='Boolean' Flags='0x0'>
</Prop>
<Prop Name='StoreUUTReportWithBatchReport' Type='Boolean' Flags='0x0'>
<Value>True</Value>
</Prop>
<Prop Name='BatchBaseName' Type='String' Flags='0x0'>
<Value>BatchReport</Value>
</Prop>
<Prop Name='LabelSize' Type='Number' Flags='0x0'>
<Value>26</Value>
</Prop>
<Prop Name='RelStylesheetPath' Type='String' Flags='0x0'>
<Value>horizontal.xsl</Value>
</Prop>
<Prop Name='StylesheetPath' Type='String' Flags='0x0'>
<Value>C:\Program Files (x86)\National Instruments\TestStand 2019\Components\Models\TestStandModels\StyleSheets\horizontal.xsl</Value>
</Prop>
<Prop Name='StylesheetMRU' Type='Array' LBound='[0]' HBound='[2]' ElementType='String' Flags='0x0'>
<Value ID='[0]'>horizontal.xsl</Value>
<Value ID='[1]'>report.xsl</Value>
<Value ID='[2]'>expand.xsl</Value>
</Prop>
<Prop Name='ATMLStylesheetMRU' Type='Array' LBound='[0]' HBound='[2]' ElementType='String' Flags='0x0'>
<Value ID='[0]'>TR_horizontal.xsl</Value>
<Value ID='[1]'>trml.xsl</Value>
<Value ID='[2]'></Value>
</Prop>
<Prop Name='StoreStylesheetAbsolutePath' Type='Boolean' Flags='0x0'>
<Value>True</Value>
</Prop>
<Prop Name='UseOnTheFlyReporting' Type='Boolean' Flags='0x0' IsAlias='true'>
</Prop>
<Prop Name='PurgeOnTheFlyResults' Type='Boolean' Flags='0x0'>
</Prop>
<Prop Name='GeneratePDFReport' Type='Boolean' Flags='0x0'>
</Prop>
<Prop Name='IncludeStepResultComments' Type='Boolean' Flags='0x0'>
<Value>True</Value>
</Prop>
<Prop Name='UseLocalizedDecimalPoint' Type='Boolean' Flags='0x0'>
</Prop>
<Prop Name='ReportStyle' Type='String' Flags='0x0'>
<Value></Value>
</Prop>
<Prop Name='ReportFileSequentialModelExpression' Type='String' TypeName='Expression' Class='ExprValue' Flags='0x0'>
<Value>"$(UserDocumentsDir)\\TestStand Reports\\$(UUTStatus)\\$(UUT)_Report_$(Unique).$(FileExtension)"</Value>
</Prop>
<Prop Name='ReportFileParallelModelExpression' Type='String' TypeName='Expression' Class='ExprValue' Flags='0x0'>
<Value>"$(ClientFileDir)\\$(ClientFileName)_Report[$(FileTime)][$(FileDate)]$(Unique).$(FileExtension)"</Value>
</Prop>
<Prop Name='ReportFileBatchModelExpression' Type='String' TypeName='Expression' Class='ExprValue' Flags='0x0'>
</Prop>
<Prop Name='BatchFileBatchModelExpression' Type='String' TypeName='Expression' Class='ExprValue' Flags='0x0'>
<Value>"$(ClientFileDir)\\$(ClientFileName)_BatchReport[$(FileTime)][$(FileDate)]$(Unique).$(FileExtension)"</Value>
</Prop>
<Prop Name='NewFileNameForEachUUTStatus' Type='Boolean' Flags='0x0'>
<Value>True</Value>
</Prop>
<Prop Name='ReportPathMacroListString' Type='String' Flags='0x0'>
<Value>$(USERDOCUMENTSDIR)$(UUTSTATUS)$(UUT)$(UNIQUE)$(FILEEXTENSION)</Value>
</Prop>
<Prop Name='BatchReportPathMacroListString' Type='String' Flags='0x0'>
<Value></Value>
</Prop>
<Prop Name='CheckIfMacroListIsUnchanged' Type='Boolean' Flags='0x0'>
<Value>True</Value>
</Prop>
<Prop Name='ATML5StylesheetMRU' Type='Array' LBound='[0]' HBound='[2]' ElementType='String' Flags='0x0'>
<Value ID='[0]'>tr5_horizontal.xsl</Value>
<Value ID='[1]'>tr5_report.xsl</Value>
<Value ID='[2]'>tr5_expand.xsl</Value>
</Prop>
<Prop Name='Atml_Rpt_Options' Type='Obj' TypeName='NI_ATMLReportOptions' Flags='0x0'>
<Prop Name='AddReportText' Type='Boolean' Flags='0x0'>
<Value>True</Value>
</Prop>
<Prop Name='ExtensionDLLAbsolutePath' Type='String' Flags='0x0'>
<Value></Value>
</Prop>
<Prop Name='TestResultsSchemaPath' Type='String' Flags='0x0'>
<Value></Value>
</Prop>
</Prop>
<Prop Name='ATML6StylesheetMRU' Type='Array' LBound='[0]' HBound='[2]' ElementType='String' Flags='0x0'>
<Value ID='[0]'>tr6_horizontal.xsl</Value>
<Value ID='[1]'>tr6_report.xsl</Value>
<Value ID='[2]'>tr6_expand.xsl</Value>
</Prop>
</Prop>
<Prop Name='StartTime' Type='Obj' TypeName='TimeDetails' Flags='0x4'>
<Prop Name='Text' Type='String' Flags='0x0'>
<Value>23:24:17</Value>
</Prop>
<Prop Name='Hours' Type='Number' Flags='0x0'>
<Value>23</Value>
</Prop>
<Prop Name='Minutes' Type='Number' Flags='0x0'>
<Value>24</Value>
</Prop>
<Prop Name='Seconds' Type='Number' Flags='0x0'>
<Value>17</Value>
</Prop>
<Prop Name='Milliseconds' Type='Number' Flags='0x0'>
<Value>19</Value>
</Prop>
</Prop>
<Prop Name='StartDate' Type='Obj' TypeName='DateDetails' Flags='0x4'>
<Value>10 March 2022</Value>
</Prop>
<Prop Name='ShortText' Type='String' Flags='0x0'>
<Value>10-03-2022</Value>
</Prop>
<Prop Name='Year' Type='Number' Flags='0x0'>
<Value>2022</Value>
</Prop>
<Prop Name='Month' Type='Number' Flags='0x0'>
<Value>3</Value>
</Prop>
<Prop Name='MonthDay' Type='Number' Flags='0x0'>
<Value>10</Value>
</Prop>
<Prop Name='WeekDay' Type='Number' Flags='0x0'>
<Value>5</Value>
</Prop>
</Prop>
<Prop Name='StationInfo' Type='Obj' TypeName='NI_StationInfo' Flags='0x0'>
<Prop Name='StationID' Type='String' Flags='0x0'>
<Value>INSL-RSHRIGIR</Value>
</Prop>
<Prop Name='LoginName' Type='String' Flags='0x0'>
<Value>administrator</Value>
</Prop>
</Prop>
</Prop>
(1,601 Views)
