NI TestStand
Hide Description column, hide Settings column
Is there a way to hide (not show) the Step Description column and the Step Setting Columns?  This looks like (too much) debug info and I need it to go away or hide it.  TestStand 2020.
Message 1 of 9
(3,063 Views)
OK, I found a way to remove/hide the columns of interest.
A first time for everything.
Message 2 of 9
(3,031 Views)
Accepted by topic author richjoh
This setting is saved in LocalAppData in SeqEdit.xml - just in case you need to copy this setting.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
Message 3 of 9
(3,018 Views)
Thanks. Excellent tip since I need to deploy automated test stations.  This can be programmatically done with the installer.
Message 4 of 9
(3,011 Views)
See this: https://github.com/425J/LayoutLoader
You might find this useful.
Michał Bieńkowski
CLA, CTA, CPI
Message 5 of 9
(3,004 Views)
In the attachment, you will also find an example of how to delete columns programmatically.
Michał Bieńkowski
CLA, CTA, CPI
Message 6 of 9
(3,000 Views)
Michal,
Can you make your sequence file TS version 2020.  I'm not using 2021 as yet.
Thanks for the tip.
One more thing, I haven't found a way to make the "Step Settings" go away and don't show.  I close it, run a sequence, return to and its back.  Let me know if there is a way.
Message 7 of 9
(2,823 Views)
So I discovered "Step Settings" will stay out of view only if it is Resize to a line then click X to close.  When it reappears after a sequence run it will appear as a line again with the X shown.
Not a 100% solution but it is out of the way. I wanted a way to make Test Setting disappear during and after a sequence run.
Message 8 of 9
(2,817 Views)
I needed to do the same, but in my case I only want to hide these columns in the operator interface. For this it was straight forward to delete them from the Execution View.
Message 9 of 9
(1,157 Views)
