NI TestStand
Hide LabVIEW Development System Icon from Application Taskbar
Hi all,
I'm using a sequence with the adapter "LabVIEW Development System 17 SP1".
When I run this sequence the LabVIEW icon appears on the Application Taskbar: there is a way to hide this? I don't want see the icon on the bar.
Other think, when the sequence is finished, LabVIEW main menu appears over TestStand: there is a way to block this behavior?
Many thanks to all.
Claudio
(3,370 Views)
Is there any reason you can't switch to the runtime adapter instead of development adapter? That will make the other application go away
https://www.linkedin.com/in/trentweaver
(3,335 Views)
Hi, I must use "LabVIEW Development System" as adapter because it's much faster than RTE
(3,328 Views)
Faster in execution or faster to load? What you wrote is surprising.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(3,276 Views)
Hi, I'm using LabVIEW 2017 SP1.
It's faster in execution. In particular, a module that call the function "LoadPrototype" (an action ActiveX) is the step where I see this.
Claudio Podavite
(3,238 Views)
