NI TestStand
Hide certain steps in the execution view
Hi All, I had a lot of nested loops in my test execution and i wanted not show it so to lessen confusion on the operators.
Is there a way to solve this issue with out using the disabling of the tracing on the subsequence?
(3,340 Views)
Have you received any help or found a solution for this? I would love to see it!
thanks!
(3,205 Views)
Unfortunatlly I don't believe its possible. My little trick has always been to put stuff in a SubSequence, Disable the Tracing, but use the ProgressPercent & ProgressText UI_Msg to show the progress within the SubSequence.
Here's a quick example.
Simon Holman
Software Engineer
Certified LabVIEW Developer
Certified TestStand Developer
measX GmbH & Co. KG.
http://www.measx.com
(3,195 Views)
