NI TestStand
High memory use in infinite loop - TestStand 2016
To start, yes:  I've read this  http://digital.ni.com/public.nsf/allkb/3A6899738157EA8986256AC5004BC0A7  🙂
Now that we've got that out of the way... I have an infinite loop running in the background that acts as a Watchdog. Previously when running TestStand 2015 I was able to disable results processing no problem like the article says and everything works great.
I just upgraded to 2016 and disabling results processing.  I now get odd behavior... when I run an infinite loop in the Sequence Editor I don't see an increase in memory.  When I run it from my UI memory rapidly increases.  I've disabled the following settings:
... and just because I was still having issues...
I'm sure I'm missing something simple here, but I'm at a dead end.
(2,969 Views)
 Ignore this post.  I'm an idiot.
(2,952 Views)
