NI TestStand
How Can I recuperate Value from TestStand UI ExpressionEdit Control in Labview
I developed a Step Type with labview and in the edit step I have a problem with my labview code. When I write for exemple locals.texte ( locals.texte = "test")  in the UI expresionEdit Control , the property node DisplayText return "locals.texte" like result and not "test". how can I use it to display the contents of the variable.
Message 1 of 11
(4,215 Views)
I am assuming you are wanting the value of the variable rather than the lookup string.
try
Regards
Ray Farmer
Message 2 of 11
(4,191 Views)
Thank you for your answer.
yes this is exactly what i want, i just tested your example in my edit step type I have an empty value, and if I call the VI in TestStand it works. is what I need to do a special configuration for my stepType to work?
Message 3 of 11
(4,183 Views)
can you post your step type project, if you can post it as LabVIEW 2015.
Regards
Ray Farmer
Message 4 of 11
(4,173 Views)
here are my VIs , my project is too bih so I will post just the two VI of the StepType ( EDIT and Post Step) with 14 like Version of LabVIEW because I don't have version 15.
Message 5 of 11
(4,163 Views)
Ok I'll have a look.
I did create a StepType using the modified VI and it worked for me. The only extra thing  I did was to make the VI a dialog in the VI properties so that it displayed the front panel when invoked by the Edit..
Regards
Ray Farmer
Message 6 of 11
(4,155 Views)
I tried your Edit VI and it worked for me.
How are you passing the value back into the Step?
Regards
Ray Farmer
Message 7 of 11
(4,152 Views)
In the parameter name  "String " I put a "Step.Text"  and Text is a String
Message 8 of 11
(4,147 Views)
So is Text a step property?
As in my example where I have Response?
Regards
Ray Farmer
Message 9 of 11
(4,141 Views)
Yes  Text is a step property, as in you example where you have Response, is what there is another configuration to do ?
Message 10 of 11
(4,105 Views)
