NI TestStand
How To Access Variables In Process Model For Use In Main Sequence
Hi everyone, in my sequence file I callback the PreUUT sequence file.  I want to be able to use one of the local variables I assign in this callback sequence in my main sequence.  In my main sequence this variable will trigger if I should run some tests or not in my main sequence.  Is this possible?  How would I do this?
Thanks so much!
(5,088 Views)
U need to make a parameter in your Callback, parameters are seen outside of sequences, then in PreUUT u will make statement to update parameter, or use the parameter in your callback  directly
Parameters.MyPara=Locals.MyLoc
etc
(5,079 Views)
