NI TestStand
How To Array of data in teststad to Excel spreedsheet
Hello NI,
I want to save my array of data in test stand arrray to  excel column wise. Is their any function to write to excel in TS.
Thank,
Kulwant Singh
(3,246 Views)
One way of doing it would be to use the code modules (I am taking the example of LabVIEW as I use that). You can have a look at some examples in LabVIEW in NI Example Finder as to how to write a file to excel sheet (1. using spreadsheet file 2. using activeX)
The other way would be to use ActiveX in TestStand which would directly interact with Excel and write your data. I dont any experience of doing that but I think the first step will be faster to implement.
Vaibhav
.......^___________________^
....../ '---_BOT ____________ ]
...../_==O;;;;;;;;_______.:/
.....),---.(_(____)/.....
...//____//......
..//____//......
.//____//......
(3,227 Views)
