NI TestStand
How To Create Run VI Asynchronously Step using the API
Ryan,
Thank you for the example solution.  I was able to use this to track down the issues with my code.  The root cause of the error was determined that a Step must be added to the Sequence before the Module.LoadPrototype can be called.
CLA, CTA
Message 11 of 11
(794 Views)
