NI TestStand
How add sequence from à directory for create a new sequence[TestStand]
Hello i would like Add sequence from a directory  in a newsequence files.
i use InsertSequenceEx but it is does'nt work
Thanks you
(3,483 Views)
Can you post a example of what you are trying to do?
Regards
Ray Farmer
Regards
Ray Farmer
(3,463 Views)
Ok In my sequence i would like choose a directory and add all file *.seq in a new sequence fille.
For exemple if in my document  there are 3 sequence , my sequence must create a new sequence files with this 3 sequence by  SequenceCall.
(3,426 Views)
Do you mean that you want to create to add all sequences contained in one directory into one sequence file? Are you using CVI or LabVIEW for the TestStand API?
Manuel R
AE dans une autre vie
(3,414 Views)
i used API Teststant but i found the solution
NewSequenceFile
Get MainSequence of New Sequence File
Get Directory (VI Labiew)
For (each file in the repertoire)
Create New Step
Get SequenceFiles
Set Name  Step
Step Module
CallModule As Module
CAllModule Use Sequence Parameter
CallModule Load Parameter
CallModule Use current file
CallModule Sequence Name
CallModule Sequence Patch
CallModule Parameter
CallParameter count
insert the new Step
      For
              Get Parameter
              Use default Value
     End
End
Statement
Save
Realease
(3,395 Views)
