NI TestStand
How can ı do Parallel Test Synchronization?
  Hi i want to do parallel test system but ı have a problem. two sequences start same time,but not finish same time. How can i synchronizate it?
(5,523 Views)
ergin,
The best way to synchronize your tests so that they start at the same time and finish at the same time would be to use the Batch process model. In addition to ensuring that UUTs start and end execution together, the Batch model also provides synchronization functions for coordinating tests between UUTs, such as having "one thread only" sections. I think this will do what you're wanting, and let us know if you have any further questions!
(5,518 Views)
I want to all sequence do same time. I didn't solve my problem. Can you help me?
(5,509 Views)
Hey ergin,
I would be happy to help, but we will need more information to assist you. Can you describe your current system in detail and what you are wanting the behavior to be? When you say "all sequences", is this multiple unique sequences in the same file that you want to execute at the same time, or do you want to run the same sequence on multiple UUTs at the same time? Any other detail you can provide would be very helpful and will assist myself and others on the forum with answering your questions.
(5,505 Views)
I want to run same sequence on multiple UUTs at the same time.
(5,502 Views)
ergin,
The Batch process model is designed for this testing scenario. Could you please provide more detail about why this did not work for your application?
(5,486 Views)
Thanks Daniel. I solved my problem thanks to you. 🙂
(5,470 Views)
