NI TestStand
How can I add own steps
Hello,"
How can I add own steps to the selection menu, so that I can insert them with "Insert Steps" in my sequence?
regards
samuel
(3,458 Views)
This is done by creating your own Type Palette.  Goto the TypePalette(Ctrl-T).  Select the MyTypes.ini and insert your Custom Step.  One of the properties from the Menu tab will ask you the name of the step and what group in the menu to place the step.
Mike
(3,452 Views)
Thank you Mike,
I have now the problem, that all properties of the created step(steps created with CVI) which I add with "specify module" (double klick on the new created step in Type palett->Substeps->Specify Module ) are not available when I add this step in my sequence. what is the problem here?
regards samuel
(3,435 Views)
