NI TestStand
How can I cancel "Description" and "Flow Properties" in Operator Interface window?
How can I cancel "Description" and "Flow properties" in Operator Interface window?
Message 1 of 9
(4,073 Views)
You would have to remove those columns from the SequenceView Control from the source code front panel and then rebuild the application.
Regards
Ray Farmer
Regards
Ray Farmer
Message 2 of 9
(4,064 Views)
Hi, where this SequenceView Control is located?
Message 3 of 9
(4,062 Views)
If you are using labVIEW then its on the front panel of the Full OI - Top-Level VI.vi in C:\Program Files\National Instruments\TestStand 3.5\OperatorInterfaces\User\Full-Featured\LabVIEW\TestExec.llb.
If you are using CVI then its on the Sequence Panel  in the TestExec.uir of C:\Program Files\National Instruments\TestStand 3.5\OperatorInterfaces\User\Full-Featured\CVI.
and so on
Hope this helps.
Regards
Ray Farmer
Regards
Ray Farmer
Message 4 of 9
(4,057 Views)
If you are using CVI, then all you need to do is modify the uir file. You dont actually need to rebuild the exe.
Regards
Ray Farmer
Regards
Ray Farmer
Message 5 of 9
(4,054 Views)
Yes, I use CVI. Thank you ! I'll try it.
Message 6 of 9
(4,052 Views)
Just open the Uir file in CVI, select the SequenceView control on the SEQUENCE_FILE panel. Right mouse click and select Properties, not the Edit Control.
Then select the Columns tab, then you can remove the two columns.
Regards
Ray Farmer
Regards
Ray Farmer
Message 7 of 9
(4,048 Views)
I'm not CVI and labview,In teststand,how to setup such function to disable the description and flow message in operation interface?
Message 8 of 9
(4,040 Views)
It works ! Thank you very much !
Message 9 of 9
(4,038 Views)
