NI TestStand
How can I cancel "Single Pass" button in Operator Interface windiow?
I've tried to cancel "Single Pass" button in OI window, I've changed TestExec.uir by deleting "ENTRYPOINT2" button, but no success. I got error message. How can I cancel this button ?
(3,490 Views)
Do you mean you dont want the Single Pass button visible on the OI. The easiest way would be to change the user privileges, cant remeber  which option its in, maybe Configure, but there is a setting for the Single Pass button enabled. The User - Operator, only has the Test UUT's button available as default.
Regards
Ray Farmer
Regards
Ray Farmer
(3,489 Views)
I think this is that I need. Thank you.
(3,487 Views)
A simple test would be to create an Operator user. Then login as that user when you launch your OI.
Regards
Ray Farmer
Regards
Ray Farmer
(3,484 Views)
