NI TestStand
How can I customise graph in Report.
I have used additional result to display the array in graph format not in table format.But how can I customise this graph.
Is their any  provision for customisation of graph adding axis and multiple line in single graph.
we can choose  graph ond table from report option.But  can we choose both as per our requirement step wise.Example for step 1 we can use tabel and for step 2 we can chose graph.
thanks ,
Kulwant Singh
(4,497 Views)
Waveform, XY, intensity, digital waveform support multiple x- and y-scales, and all charts support multiple y-scales. Mixed signal graphs support only one x-scale. Use multiple scales on a graph or chart to display multiple plots that do not share a common x- or y-scale.
Complete the following steps to add a scale to a waveform graph or chart.
  1. Right-click the scale of the waveform graph or chart and select Duplicate Scalefrom the shortcut menu.
  2. To move the new scale to the opposite side of the display, right-click the new scale and select Swap Sides from the shortcut menu.
  3. Associate a plot to the new scale by right-clicking the plot in the plot legend and select from the X Scale or Y Scale shortcut menus. If the plot legend is not visible, right-click the graph or chart and select Visible Items»Plot Legend from the shortcut menu.
  4. To change the range of the new scale, use the Operating tool or the Labeling tool to highlight the end value(s) of the scale and enter a new value. If you set the scale manually, you should disable autoscaling.
I did not get the second part of your question, please clarify on that.
(4,481 Views)
Hello MR. Anonymous,
Thanks for your kind help.
Actually I am talking about NI teststand not LabVIEW.Smiley Mad
I didn't mentioned the product as it is teststand forum.Smiley Wink
Thanks again.
With warm regards,
Kulwant SinghSmiley Happy
(4,478 Views)
I think you need to see what can be done in reportgen_html.seq because this is the file which generates the report.
the report options callback is actually called before the  sequence is run so thr is no point adding the steps there.
Reply if you get something.
regards,
Vaibhav
.......^___________________^
....../ '---_BOT ____________ ]
...../_==O;;;;;;;;_______.:/
.....),---.(_(____)/.....
...//____//......
..//____//......
.//____//......
(4,452 Views)
I have a similar problem: I have a VI which has as output an analog waveform. I use this VI in my teststand sequence and this output has been configured as additional result. The displaing of the waveform in testreport is working fine, but the problem is that the Y-scale will be scaled automaticaly and scale labels are not more available. Unfortunately it looks like the settings in VI will be ignored by teststand while generating of the testreport. I'm using xml as report format and expand.xsl stylesheet. Some users talked about modifications in reportgen_***.seq, but is it only possibility to resolve this problem? Did alredy anyone experience with this?
Thanks and regards
(4,027 Views)
TestStand 2010 supports some customization of graphs in reports via attribute settings. See the following for more details:
https://www.ni.com/docs/en-US/bundle/teststand/page/displaying-measurement-data-as-graphs.html
-Doug
(3,999 Views)
