NI TestStand
How can I detect if a step was skipped?
In a C-Sharp application, is there a way to detect if a step was skipped when the execution has completed?
ApplicationMgr.GetRunState() and ApplicationMgr.GetTerminationState() don't tell if the execution was complete (nothing skipped) or incomplete (1 or more steps skipped).
Do I need to walk through the steps and use the Step.GetRunModeEx() method?
(3,761 Views)
Accepted by topic author tlaford
Hi tlaford,
You will still need to check each step, but I believe that what you are trying to achieve would be better accomplished through the use of Step.ResultStatus:
ResultStatus Property
Syntax
Step.ResultStatus
Data Type
String
Purpose
Specifies the status string for the step.
Remarks
Although you can define custom status strings, this property is usually set to one of the StepProperties constants.
Ryan T
(3,712 Views)
Can you explain a little more of what you are trying to achieve.
What is this C# application, a User Interface?
Regards
Ray Farmer
Regards
Ray Farmer
(3,697 Views)
Our application is a GUI wrapper around TestStand to hand hold the user through the selection of a test, installation of the proper equipment on the testing hardware, and execution of the test.  I was looking for a way to determine if a step was skipped once the test sequence has completed.  Based on what I have read, there isn't and I will need to look at each step's ResultStatus.
(3,689 Views)
