NI TestStand
How can I determine overall test status of a sequence in cleanup before test completes
I want to insert an if condition and base it off the overall test result of the sequence.  Based on the test result I would then run a particular call to another step.  Where can I find the overall result of the test?  Root.Runstate.x.x.?????
(3,087 Views)
RunState.SequenceFailed is what you are looking for.  However, it's kinda tricky because if it's true then you have a failure.  If it's false then the sequence passed.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,070 Views)
