NI TestStand
How can I dynamically set VI Path in TestStand
I have a noob question here.
Is it possible to dynamically set the root VI Path to my PPL file in TestStand? For example, one of my *.vi code resides in a PPL (e.g. "C:\Deployment\LV2019\ProductX\FunctionalTest\PPL\FunctionalTest.lvlibp\TS-Modules\Instruments-CreateInit.vi").
Is it possible to dynamically change the root path to the PPL in TestStand without having to check the search directories?
In my case, the root would be "C:\Deployment\LV2019\ProductX\FunctionalTest\PPL\".
Message 1 of 1
(2,453 Views)
