NI TestStand
How can I exactly pass parameters from a subsequence to the main sequence?Dp you have any examples?
In the Sequence Editor is a Tab called Parameters.
You add your variable(s) here which are passed or returned from a sequence call. By default the variables inserted are classed as'By Reference'. You can change this to 'By Value' when you select the step and right click on the step you will find the options in the popup menu. 'By Reference' will allow data to be returned to the calling Sequence.
When you insert a sequence call, you would then have to Specify the sequence to call. Any variables in the subsequence's parameters list will be displayed in the Specify Dialogbox. Select each of the parameter to define what data is being passed.
I have added a simple sequence file to demo this.
Hope this helps
Ray Farmer
Regards
Ray Farmer
(3,876 Views)
Thank you very much, it's been very useful for me.
(3,876 Views)
