NI TestStand
How can I find what code is modifying a variable?
I have a weird one.
I am using the normal sequential model.
Something in my code is adding a property (container + string) to UUT.AdditionalData.  It's not the end of the world, but I can't pinpoint WHEN it's happening.
It's getting added between Pre-UUTLoop and Pre-UUT.
If I go to the model and put a breakpoint before Pre-UUT, there is no subProperty after PreUUT Loop runs.
When I clock STEP INTO on Pre-UUT, it's there.  Instantly.
I have searched for the property name in all my sequences, and I have found the code I wrote that creates it.  But that code runs well after this point.  I added a BP to it just to check and sure enough it happens later on.  (That step also creates a bunch of other variables, so that's not the code that's causing this).
It's POSSIBLE that I put this into labview code that's getting called, but there's no way it's running async and waiting for the engine to enter PreUUT.  And I checked the threads, there's two, but one is not running code (just used to launch an external utility and waits for it to exit).
Is there a way to block changes to a variable at runtime, and then have TS throw an error?  That would at least point me to what's trying to mod it.
(478 Views)
Did you customize your process model at all, or using any specialized model plugins?
(444 Views)
Maybe it doesn't exactly help, but if you define a watch for this object, you can define a breakpoint on value change.
(439 Views)
