NI TestStand
How can I get a list of the names of the failed steps ?
   I wanted to have a string which can describe all the failed steps. For example, if I had the steps below :
Step 1
Step 2
Step 3, etc
and Step 1 and Step 3 failed, how can I get a string " Step1, Step2" ?
Can I somehow add a variable in each step which records the step result and then use all the variables at the end to creat a Result string ?
Please help.
~Sam~
(2,974 Views)
Sam,
you have at least two possibilities for your question:
a) use the "SequencePostResultListEntry"-callback. You can check the "Step.Result.Status". If it is failed, you can copy the stepname into a string-variable which builds your "string"
b) In the end of your MainSequence, just browse your ResultList for every step which has Result.Status as failed. Copy all stepnames into your string.
Both methods require your station to record results, but since this is defaultsetting, there shouldn't be a problem.
hope this helps,
Norbert B.
Norbert
Expert: Geometry
(2,962 Views)
