NI TestStand
How can I get the filename of the actual report file while the test is running?
I have to send the name of the actual report file to the Operator Interface.
Is there anyone knows where to get that info when the sequence is running?
Andras
(3,147 Views)
Andras,
you should take a look into RunState.Root.Locals.ReportOptions.ReportFilePath. Please note that this i a runstate-property so you should have a problem to find it during edit-time.
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,137 Views)
Yes Norbert it helped, thanks.
Except RunState.Root.Locals.ReportFilePath holds the value in TS4 instead of RunState.Root.Locals.ReportOptions.ReportFilePath.
Thanks again,
Andras
(3,115 Views)
