NI TestStand
How can I get the full VI path of a step?
I can get the VI file name by with Step.TS.SData.ViCall.VIPath but is it possible to get the full path?
CLED (2016)
(3,457 Views)
TestStand uses relative paths, so it never actually stores the full path to the VI unless you specify an absolute path.
If you would like to find the full path of where it has been found, you can use the method Engine.FindFile or the expression function FindFile to find where TestStand is locating this file.
Matt M
NI
(3,441 Views)
 I feel dumb for not knowing about that function. Thanks!
CLED (2016)
(3,434 Views)
