NI TestStand
How can I implement the function atof in TestStand?
I would like to convert a string to a number.....same as   num = atof(aString);
How do you do it with TS functions?
(3,389 Views)
Val(locals.MyString)
Documentation is in the Expression Browser>>Operators/Functions Tab>> Functions - Numeric>>Val
(3,385 Views)
Rafi,
There is an expression function used to convert strings to numbers.
Val( string, <isValid> ) ->Converts a string to number.
Hope it helps.
Antonio Lie.
Message Edited by Antonio Lie (NI) on 10-04-2006 11:19 AM
(3,384 Views)
