07-05-2007 06:34 AM
07-06-2007 08:58 AM
07-06-2007 10:24 AM
07-09-2007 09:41 AM
Hi Diana,
It work fine. Thank you. However I would need to mdify the report generation to make the results looklike Hyperlinks as you suggested. I have many steps to change if I want to do it in the post expression.
I would need some solution, which is done in only one place and all my ReportText properties become hyperlinks in the generated report.
Do you have any suggestions?
Thanks again for your help!
Andras
07-09-2007 09:59 AM
07-09-2007 10:38 AM
