NI TestStand
How can I make a custom one-line-per-test rpt using TestStand?
I have written a 1-line-per-test report in another LabView application.  How can I do the same within TestStand 4.0?  I would like to display the usual information:  Description, Measurement Reading & Units, Pass/Fail, Lower Limit, and Upper Limit all in a concise, one line rpt.  Isn't most of this data available within TestStand?
(3,142 Views)
If you are using TS 4.x, you can use the horizontal XML format report. Otherwise you will have to modify one of the report generation sequencefile (probably the text version) to produce the effect you require.
Regards
Ray Farmer
Message Edited by Ray Farmer on 05-21-2008 06:42 AM
Regards
Ray Farmer
(3,133 Views)
I would have figured this to be a pretty common use case, so I was wondering if anyone has made/edited a report sequence that does this?
For example, the default report text looks something like:
UUT Report
Serial Number:                MACADDRGoesHere
Date:                         Monday, September 22, 2008
Time:                         9:48:05 PM
Operator:                     administrator
UUT Result:                   Passed
Begin Sequence: MainSequence
(C:\Projects\Corventis\1-08-01641-Corventis-Gen1 PCBA Test System\Engineering\3 - Develop\Sandbox\Report Generation Demo\Report Generation Demo_Main.seq)
V_CPU_2V5 (Device Off):        Passed
     Measurement:              0.3000
     Units:                    V
     Limits:
        Low:                   0.1000
        High:                  0.5000
     Comparison Type:          GELE (>= <=)
     Module Time:              0.0014
Memory DataBus Test POST:      Passed
     Module Time:              0.0012
V_BATT:                        Passed
     Measurement:              3.1200
     Limits:
        Low:                   3.0000
        High:                  3.2000
     Module Time:              0.0009
End Sequence: MainSequence
End UUT Report
whereas I'd love something like:
UUT Report
Time:                         9:48:05 PM
Execution Time:               0.2188 seconds
Test Name        Result        Measurement        Units        Limit Low        Limit High        Comparison Type        Module Time
V_CPU_2V5 (Device Off)        Passed        0.3000        V        0.1000        GELE (>= <=)        0.0014
Memory DataBus Test POST        Passed        N/A        N/A        N/A        N/A        N/A        0.0012
V_BATT        Passed        3.1200        3.0000        3.2000        GELE (>= <=)        0.0009
End UUT Report
Message Edited by crelf on 09-22-2008 10:19 PM
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(2,980 Views)
