NI TestStand
How can I open a sequence file directly
I use a changed CVI Operator Interface (TestStand 3.1) and I will open a sequence file directly and NOT via 'File -> Open Sequence file...'.
The reason is, I have a lot of sequences in the same directory and I prepared an extra menu item to select a sequence file in a UUT related tree. After I have selected the sequence file I will open this sequence file but I d'ont how to do it.
Best regards Jef,
(3,121 Views)
Hi Jef,
1. create a link to your CVI "Operator Interface (TestStand 3.1) .exe" in your personal 'sendTo' directory
    or in the 'Default User' environment.
2. to avoid multiple windows of your application add the following expression to the link:   /useexisting "%1"
3. now you can use the right mouse click on a sequence file to use the 'sendTo' option for it
Sunny
(3,112 Views)
