NI TestStand
How can I query TestStand Database quickly?
Hello everybody:)
I have a performance issue with default TestStand database what puzzled me for long time.
In default database TestStand organize the different test item to different table, if I want to query a test record according to a special Serial Number, the query will look into UUT_RESULT at first to find a GUID then forward to the other table to find a series of GUID bound with this SN which will be used to go into different tables like a numeric values table or pass_fail table to find out the result of each test step.
Half a year ago, we have a small tool embeded with customized TestStand Interface to access this SQL Server 2005 Express database to fetch a SN and all its test results details for faulty analysis. Recently I found it will cost me more than 2 minutes to fetch all related test results of one SN, I tried to write some query in SQL SERVER management studio to get the same thing, the case is still there. And also I check the tables, all tables are already indexed, so I'm quite confused.
Did someone meet similar thing with me? Can you provide some suggestion on this?
*The best Chinese farmer*
(3,350 Views)
What exactly is the query that you are using? Depending on how many records you are attempting to retrieve, two minutes may not be unreasonable. If the database is on a network share, if others are attempting to do similar, large queries, can also affect performance. Making your query into a stored procedure could save some time.
(3,346 Views)
