NI TestStand
How can I read a step's requirements? Step.Requirements doesn't display reqrmt.
In TestStand, each step or sequence has a requirement property.  When one type a requirement in for a step , the requirement text will appear on the Requirements column or a step.
I try to read the step's requirement by using Step.Requirements, but Step.Requirements object is PropertyObject, and it does not have a property or method to display the step requirement.
Please let me know how I can access/read the step's requirements.
My email address is anh.t.doan@boeing.com.
Thank you.
Anh Doan
(4,035 Views)
The requirements PropertyObject is an array of strings.  You can access each individual item by using the following method:
PropertyObject.GetValStringByOffset
You will need to know how many requirements there are, so you will need to know the array size.  You can use the method:
PropertyObject.GetNumElements
Allen P.
NI
(4,031 Views)
Hi Allen,
I follows your suggestion, but it does not work as follows:
1. On the step that I try to print out its requirement,  I have the following statement in the step's Post-Expression:
    Locals.NumElements = RunState.Step.Requirements.GetNumElements()
where Locals.NumElements is a local variable having type of Number.
I ran it and got the following error:
The post-expression for the step 'ROM Test' could not be evaluated.
Error in call to TestStand API member 'PropertyObject.GetNumElements'.
Specified value does not have the expected type. [Error Code: -17308]
2. I then tried the following statement in the step's Post-Expression:
    Locals.Requirement_String = RunState.Step.Requirements.GetValStringByOffset(0,0)
where Locals.Requirement_String is a local variable having type of String
Error in call to TestStand API member 'PropertyObject.GetValStringByOffset'.
Please let me know how I could fix this to read the requirements.
Thank you,
Anh Doan
(4,013 Views)
Sorry for the mistake!
The Requirements are stored in a subproperty (Links) in this object.  You can use the following code instead:
Locals.NumElements = RunState.Step.Requirements.Links.GetNumElements()
and
Locals.Foo = RunState.Step.Requirements.Links.GetValStringByOffset(0, 0)
Allen P.
NI
(4,010 Views)
Allen,
Your new syntax works great!   I could read the requirements now.
Thanks a lot!
Have a nice weekend!
Anh Doan
(4,006 Views)
