NI TestStand
How can I run two sequences simultaneously on the same UUT
I am trying to run two sequences in parallel on the same UUT (only one UUT) so that I can set a piece of equipment to a certain state while starting a timer simultaneously.  How can I do this in the teststand sequencer?
(3,032 Views)
Accepted by topic author mcfrenzy36
You can execute a sequence (or a sub-sequence if you just need a timer) in a new thread (just choose "use new thread" in the sequence call)
Rodéric L
Certified LabVIEW Architect
(3,030 Views)
