NI TestStand
How can a separate thread terminate TestStand execution?
I have a separate thread that is started by calling a DLL from TestStand. It monitors UPS fault bits using a simple DIO. When a fault condition occurs, I need TestStand to terminate execution. How do I accomplish this using TestStand?
(3,781 Views)
Easies way would be to Call the method Engine.TerminateAll
Regards
Ray Farmer
Regards
Ray Farmer
(3,777 Views)
Within my C# code, which library do I include?
(3,735 Views)
Howdy Jeff -
You can find the Engine.TerminateAll( ) method in the NationalInstruments.TestStand.Interop.API assembly.  It is located in <TestStand 3.5 Dir>\API\DotNet\Assemblies\CurrentVersion.
Have a great day!
Andrew W || Applications Engineer
(3,714 Views)
