NI TestStand
How can i automatic create testplan label steps from textfile?
i have textfile with multiple lines.
Each line should become the name of a label in a testplan.
How could i do this automatically?
Thank you
(1,544 Views)
I might be confused by what you are asking.
Are you looking to turn each line in your ascii file into a step in TestStand?
Are they all going to the same file and sequence?  Which step group would you want them to show up in?
I don't think this is completely achievable in TestStand only.  You would need to use a code module like LabVIEW or C#.  But basically you could create a Tool in TestStand that would call some code to read the ascii file and iterate through each line.  Then using the TestStand API inject steps into a sequence and sequence file.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(1,494 Views)
Ok, what if i have the ASCII file then in a Stationglobal stringarray.
How can i create for each Index of the array a new labelstep in mainsequence?
(1,490 Views)
Accepted by topic author OnlyOne
I threw this together real quick.  Just run the Insert Label Steps sequence and the MainSequence will have the label steps.
Hope this helps.
jigg
CTA, CLA
testeract.com
(1,487 Views)
IMHO, that's a great example. Quick, simple and efficient.
Mateusz Owczarek
Certified LabVIEW Architect
Certified TestStand Architect
(1,478 Views)
