NI TestStand
How can i faster modify the entries in Step Type Menu Editor ?
i created some custom tests and actions by copying the original testtype in Types (STRG + T)and liking them to my own DLL.
After coping the name is first "Action_2" which i rename to "Action_Reset".
On the left side i can rightclick on the seqeunce filename and select "Step Type Menu Editor" which opens a small window where my new copied Action is now in the same Group as the original NI-Action.
I created a new Group "Button Add Group) and moved my action into there.
This is what is working.
The problem is that this takes to much time for >300 custom teststeps/actions which have to be sorted into different groups.
So can i make the sorting also in an text-editor? Or is there any other faster way to do this?
Thx
(3,851 Views)
Hello OnlyOne,
adding custom data/step types is possible. Here are some little examples how to deal with the TestStand API:
Creating a New Step Type in a TestStand Sequence File using C# - National Instruments
http://www.ni.com/example/30280/en/
How To Create A Custom Datatype Programmatically - National Instruments
http://www.ni.com/example/28606/en/
Greets,
Brandy
(3,806 Views)
