NI TestStand
How can i set Loop Type in Loop Options for specific step?
Hello everyone.
How can i set  proggramly Loop Type(None,Custom,Fixed number of loops or Pass/Fail count) in Loop Options for specific step from my application and not from TestStand dialog?
I use LabWindow CVI 8.0.
For example, i use function "TS_StepSetRunModeEx" for setting Run Mode of step from my application.
Did i have a same function for setting Loop Type?
I was fined some defines in file tsapicvi.h:
#define TS_StepLoopType                               0x0000003C
#define TS_StepLoopWhileExpression           0x0000003D
#define TS_StepLoopStatusExpression          0x0000003E
#define TS_StepLoopInitExpression                0x0000003F
#define TS_StepLoopIncExpression                0x00000040
#define TS_LoopType_NoLoop                       "NoLooping"
#define TS_LoopType_FixedNumLoops         "FixedNumLoops"
#define TS_LoopType_PassFailCount           "PassFailCount"
#define TS_LoopType_Custom                      "Custom"
Can i use this defines for solving my problem? In which functions this defines is usefull?
Thank a lot,
Olga
(3,173 Views)
Olga,
You can use TS_StepSetLoopType.
Regards.
Hope it helps.
Antonio Lie.
(3,164 Views)
